Quickie: Write to measurement file VI, how to create new file?
I am using the write to measurement file express VI in my code and I have wired into it a control that sets the location to save the measurement file
The only problem is the measurement file has to exist first!! I cant for example, from the front panel, click the browse directory box, navigate to a folder and type in a name for the file. It just says file not found! Its like the file directory control is opening a file to save to, rather than creating a new file in that location
How can I solve this?
(3,172 Views)
Simple. Right click and select 'Browse Options'.
(3,167 Views)
Can you post what you have so far?
Tim
GHSP
(3,165 Views)
Project attached
If I go in browse options what do i do? Just chose new and existing files?
(3,161 Views)
Accepted by AlexMason86
@AlexMason86 wrote:
Project attached
Uh, yeah. There is also a help button there.
(3,158 Views)
seems to work! Great Thanks!!
said it would be a quickie
(3,154 Views)
OMG!  Its a file path option; not a VI option...Thanks!
(2,743 Views)
