Queues containing a 2D array?
I have taken over a program that set time stamps on neutron pulses coming from two different detectors. These time stamps are then put in a queue and if the queue contains any data these will be written to a file for later analysis. My problem is that I want to be able to determine from which detector a certain pulse came. So, I wonder if the queue could contain a 2D array where in the first column I put the times for the neutrons in the first detector and in the second column I put the times for the second detector. Is this possible?
If not, can I have more than one queue in the program (so that each detector has an own queue)?
Thanks in advance
Erika
(8,310 Views)
Accepted by topic author ErikaN
Hi Erika,
you can use a 2D array as queue data, see the attached picture. You can also use two or more queues in your program. I would use two queues to solve it.
Mike
Message Edited by MikeS81 on 03-18-2009 02:09 PM
(8,307 Views)
Hi Mike,
Thank you for your quick answer! Two short "follow-up" questions:
In the Enqueue Element can I specify in which column I want to add a value?
Is it faster to use two queues?
Erika
(8,278 Views)
Hi Erika,
no you can't, you can only add a new 2d Array as new element. I think two queues would be faster, but the main advantage is that you can handle them independently.
Mike
Message Edited by MikeS81 on 03-18-2009 04:10 PM
(8,275 Views)
MikeS81 wrote:
Hi Erika,
Mike
My guts says the contrary since it would be double the work (but 2 X zero is still a small number Smiley Wink).
Two queues would introduce complications trying to figure which element from this queues goes with which element for the other queue.
Just my 2 cents,
Ben
(8,266 Views)
If you simply want a 2D array in memory and replace elements, columns, rows, etc. as desired, you might want to create an action engine that contains a single 2D array in a shift register.
Detector 0 would write to row 0 and detector 1 to row 1, for example while the read action would read both columns.
Message Edited by altenbach on 03-18-2009 09:03 AM
(8,249 Views)
