Queue Operations
Consider One enqueue is created , in two places it is dequeued but should get the same element out, how is it possible using the queue functions?
(2,229 Views)
That will not be posible with one Queue.
A Queue is on the basis, a One to One or Many to One stream of data.
If you want a One to Many, you need to look at Notifier or User events.
(2,205 Views)
Queues are Many-to-one, Events are One-to-many. You want events instead.
Qestit Systems
Certified-LabVIEW-Developer
(2,201 Views)
As Already commented, Queue is best for N to 1 and Value needs to be processed, Notifier is best for N to N.
Check the link below for detailed differences between Queue and Notifier.
https://forums.ni.com/t5/LabVIEW/Difference-between-Queue-and-Notifier-how-it-use-in-LAbview/td-p/26...
(2,199 Views)
