Plus Equal in Labview?
I wonder if there is a Plus Equal Funktion in Labview like I can Programm in C?
Message 1 of 8
(4,080 Views)
"+=" works on variables. In LabVIEW you almost never need them. Think dataflow. Provide an example where you think you need "+=" and we can discuss that example.
Certified LabVIEW Architect
Message 2 of 8
(4,061 Views)
Or for C programmers: Every operation in labview works like "+=" in C.
From this point of view, there is a lot missing in C 😋
Message 3 of 8
(4,056 Views)
That's a good point. Its built-in:
Message 4 of 8
(4,051 Views)
Thanks for your help. The example is attached below.
Message 5 of 8
(4,049 Views)
Accepted by topic author Spurbruenette
The question and the answer:
Use a feedback node (or shift-register).
I changed the value of the constant in your example. If you want to us the constant to initialize the indexing, you can do it like described. Or just not connect it if it shall start at 0.
Message 6 of 8
(4,036 Views)
Thats what i needed. Thanks for your quick help!
Message 7 of 8
(4,032 Views)
Increment (+1) is the closest i think.
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(4,003 Views)
