Question regarding the spreadsheet example
Hello everyone,
I am new in the labview.I am using the labview 2013. I am stuck with the one problem.
I have a huge spreadsheet file which have a large number of rows and column. I am able to read out the file but my problem is I am not able to read out the perticular row which have a integer and alphabet. e.g.(I have a file like this)
Port 1  Port 2  Port 3....Port 170
20.55   25.45  26.47     20.45
23.65   30.67  28.55     29.55
 Now I have to read out the first row and then make a function that locate the port number. for example if I want port 100 value for calculation then by that function I have to able to find the location of port and then I will use that port column value for the different calculation. Is it possible with labview??
Maulik
(3,684 Views)
Hi Maulik,
This can be done in LabVIEW, through the read from spreadsheet VI. There is an example on how to use this VI in a similar way to your goal posted on the NI Community.
https://forums.ni.com/t5/Example-Code/Read-Data-from-Spreadsheet-csv-and-Display-in-LabVIEW/ta-p/351...
Also for reference:
http://zone.ni.com/reference/en-XX/help/371361K-01/glang/read_from_spreadsheet_file/
- FCTesting
(3,678 Views)
thank you very much for your reply it would be helpful for me.
but my main problem is I have a 170 column and i want to make a function which directly locate the port.
for example if I write in a function- port 101 then it reads automatically in which row and column this port is and show me that column of port.( I think the row should be the same for all ports but only I have to find is location of the column of port.)
Example if I type port 101 (ans would be) =[ row 5 column 90] and from column 90 i have to pick values and calculates the other values.
its bit complicated to understand.
regards,
Maulik
(3,671 Views)
Any one find solution for my requirement??
Is it possible in labview?
(3,663 Views)
I dont really get what you mean with your example, maybe some code.
But the you can easily read a row from a column using the index array.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(3,658 Views)
Accepted by mrdesai88
Yes thats the double character I can read. But I have a row like,
e.g ROW 5 : Port 101  Port 102  Port 103 Port 104 ..... Port 171
this type of row I am not able to read.
Maulik
(3,642 Views)
Ok I got my answer.
Thank you all for your kind help.
(3,639 Views)
