08-08-2005 11:10 AM
08-08-2005 10:42 PM
09-14-2005 11:19 AM
The goal is to be able to access data from machine into LV and then have it transferred automatically into a Access report. This is a personal project and right now I have only began to just have the LV and Access talking to one another.
Do you have any suggestions on the above goal.
09-14-2005 02:27 PM
09-14-2005 02:56 PM
In the interest of not re-inventing the wheel, you may want to have a look at LabSQL:
http://www.jeffreytravis.com/lost/labsql.html
I've played with it for a few minutes and it appears to work as advertised. I haven't had a chance to use it in my coding.
Sheldon
09-15-2005 09:05 AM
The code basically looks real good. Two suggestions: First, I would make is to move things around a bit so its clearer where things are connected. This sounds minor I know but its no fun spending hours troubleshooting code only to find that a wire isn't connected where you thought it was...
Second, because this is going to be a subvi in something larger, bring out the Error In and Error Out to the front panel/connector pane. You don't want to use NI's error handler in a subvi. You want to bring out your error chain so it can be used to establish a natural data dependency with other subvis in the higher-level application.
Remember error/status data is also data worth managing.
