Question on my Access Table VI
I have attached a code for my table that acquires data using access.
Does anyone have input on how I can make it better?
I am trying to create a table using LV that acquires and enters data so that novice users can easily manipulate data with LV.
Thanks for all your help in advance.
(3,237 Views)
Well the code you have will certainly allow a user to manually edit the values in one table--but then so would opening Access and editing the table in it's tabular views. Which I guess is a long way of saying I don't see what this program will acomplish that other tools can't do better. Plus, in a well-designed database, the ability to interactively modify one table at a time through a spreadsheet-like interface isn't really very useful.
What is the goal of the overall application you're designing?
One big suggestion: lose the database connectivity toolkit. It injects a lot of unnecessary complexity to a process that is basically pretty simple.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,217 Views)
The goal is to be able to access data from machine into LV and then have it transferred automatically into a Access report.  This is a personal project and right now I have only began to just have the LV and Access talking to one another.
Do you have any suggestions on the above goal.
(3,185 Views)
I have attached VI that reflects what I am doing so far.
Please know I am looking for constructive criticism.
If anyone can help, thanks in advance.
(3,167 Views)
In the interest of not re-inventing the wheel, you may want to have a look at LabSQL:
http://www.jeffreytravis.com/lost/labsql.html
I've played with it for a few minutes and it appears to work as advertised.  I haven't had a chance to use it in my coding.
Sheldon
Technical geek, engineer, research scientist, biodegradable...
(3,162 Views)
The code basically looks real good. Two suggestions: First, I would make is to move things around a bit so its clearer where things are connected. This sounds minor I know but its no fun spending hours troubleshooting code only to find that a wire isn't connected where you thought it was...
Second, because this is going to be a subvi in something larger, bring out the Error In and Error Out to the front panel/connector pane. You don't want to use NI's error handler in a subvi. You want to bring out your error chain so it can be used to establish a natural data dependency with other subvis in the higher-level application.
Remember error/status data is also data worth managing.
The only other caution is (as I stated in my earlier post) about the use of the toolkit, but if its working for you right now don't worry about it too much. Just know that long-term there are better and cheaper ways of making the connection.
Mike...
LabVIEW Champion
(3,146 Views)
