04-29-2021 01:11 AM
In the FPGA IP Builder example attached, In the CORDIC VI why are the values of x, y and z limited to <1, also how are the ztable array values selected.
As per my understanding of CORDIC z' = z - (di)(angle)
where angle is selected such that, angle = atan 2^i
and i is the iteration count.
di is the decision factor.
But this is not the case in the example presented.
I am trying to understand how High throuhput Natural logarithm works, and after reading about it I have come to a conclusion that it uses CORDIC so I am trying understand CORDIC and how it is implemented in FPGA.
05-01-2021 12:48 PM
Thank you for posting and asking the question "What is the CORDIC Algorithm" (I could see its implementation in your code, but had no idea what it was really doing ...).
So I looked it up! Fascinating. CORDIC is an acronym for COordinate Rotation DIgital Computer, which uses a series of shifts, simple logic (basically sign of the intermediate result) and an extremely clever way of building up an arbitrary rotation angle (angles are chosen such that their tangents are well-approximated by a shift, i.e. they represent a power of 2). Using this, it is really fast (and needs almost no "fancy computation") to express functions such as sin(x) or arctan(x).
Here's one site that develops the idea: An Introduction to the CORDIC Algorithm .
05-03-2021 12:21 AM
Thank you for your response.
I am aware of the mathematical aspect of CORDIC algorithm and its applications. My question was how is it implemented in Labview FPGA inside a SCTL, as it is iterative I don't think it is possible to implement it without pipeline. Also the code that I attached is an example code from Labview 2019.
The values of z' in cordic are selected in cordic such that z' = zi - di * atan(2^-i)
where zi and di refer to the ith iteration. However the values present in the ztable array in the given example do not correspond to atan(2^-i), which according to me should be 45, 26.56, 14.036, 7.12, 3.576 and so on for i = 0,1,2,3,4,...
05-03-2021 04:05 PM
Ah. That I understand. For the algorithm to work, you need to have representations of atan(1), atan(0.5), atan(0.25), atan(0.125), etc. The values in the table are simply 2^14 (=16384) * [atan(1), atan(0.5), atan(0.25), atan(0.125), ...]. Note that multiplying by a power of 2 in an FPGA amounts to a bit shift -- can you figure out why you shift by 14? [Hint -- it has to do with maintaining maximum precision without worrying about a sign bit].
05-10-2021 07:45 AM - edited 05-10-2021 07:45 AM
Unfortunately that is not the case here. I had already considered this possibility.
You see the values in the table are 16384, 9672, 5110, 2594, 1302, 652, 326, 163, 81, 41, 20, 10, 5, 3, 1, 1
Whereas according to the logic you mentioned the values should have been 16384, 8192, 4096, 2048, 1024, and so on which is not the case....
05-10-2021 07:51 AM - edited 05-10-2021 07:53 AM
Hi linu,
Let's see:
45.00 is represented by 16384
26.56 is represented by 9672: 26.56745*16384=9670.2
14.04 is represented by 5110: 14.04/45*16384=5110.8
7.12 is represented by 2594: 7.12/45*16384=2592.3
Do you see the pattern? (Apart from rounding errors…)
05-10-2021 08:04 AM
Yes, I understand now. Thank you very much for the help.
