Question about for loop
I am using labview 7.1 to communicate with red tide USB 650 spectrometer. In my program I want a certain function to operate 32 times and the whole set of 32 functions to operate n times. i was thinking about using one "for loop" inside another with the No. of iterations of inner loop as 32 and for outer loop as n. Will this give me 32 complete iterations in the inner loop in every one iteration of the outer loop?
Thanks in advance!
(3,874 Views)
Yes.
Should i expand?
Never say "Oops." Always say "Ah, interesting!"
(3,865 Views)
That is correct. The outer loop may only proceed to the next iteration if everything inside it has finished executing. A loop will only finish its execution if it terminates due to the termination condition; a "standard" for loop has only a single terminal condition: i == N.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,864 Views)
It should give you what you are looking for. It would be easier if you show a sample of your code so it can be evaluated but if you do it the way you explained it should work.
Tim
GHSP
(3,860 Views)
Most definitely!
Whenever I have questions about nesting like this, I just use the highlight execution mode (the little "lightbulb" button on the block diagram window) and watch the loops run.
(3,859 Views)
Thanks everyone for the help! Smiley Happy
(3,851 Views)
