Build unsuccessfull product not found on the system or has been upgraded: daqmx 8.7
I get the following error when doing a build:
The build was unsuccessful.
The following product(s) are not found on the system or have been upgraded:
NI-DAQmx 8.7
I just upgraded from LabView 8.6 to 8.61.
Any ideas?
(2,258 Views)
Hi Friend
You haven't mentioned whether it is occurring while building exe or installer. And I hope this occurring when building a installer. You just try this
Go to installer properties under category select "additional installers" and uncheck all items under the "national instruments installers to include" and then build. If its builds successfully there is no problem in your exe.
You can make separate installer of corresponding Run time engine and Device Drivers from the labview DVD.
This problem may happens when the installer failed to find the path of labview source distribution DVD where the Run time engine and device drivers are located.
Regards
Sam
samuel@captronicsystems.com
(2,253 Views)
