Quanser DC Motor Control Trainer missing VI's for labview 2009
Hi my name is phillip, a student developer working with labview 2009 and the Quanser DC Motor Control trainer with ELVIS II. I have failed to run the VI for speed control, it appears to be broken and says four sub-vi's are missing and they are "Intergrator.VI," "Integrator (DBL).VI," "Transfer Function.VI," "and "Transfer Function (DBL).VI.". I happen to have installed the control design and simulation toolkit but this has not solved the problem. Please help!!!!
Message 1 of 16
(4,609 Views)
Hi Phillip,
You also need to install the "PID Control Toolkit" module for those QNET VIs.
Let me know how it goes,
Mitch
Message 2 of 16
(4,589 Views)
hey mitch,
I discovered the  VIs i had were for ELVIS I and thats what led to the errors. managed to get those for ELVIS II and they worked perfectly and now I can control the motor. Thanx  alot for your suggestion...
Message 3 of 16
(4,557 Views)
Hi Phillk, I have the exact same problem with the missing VIs for the Quanser DC motor control with the NIELVIS also for Labview 2009.
Can you please tell me where I can find these VIs? Can you send them to me if it is possible?
I would really appreciate it,
I need the Transfer Function.vi,  Transfer Function (DBL).vi and the integrators too.
Thank you,
Carlos M. Rodriguez
cmrodri4@mail.usf.edu
Message 4 of 16
(4,435 Views)
Hi Carlos,
The "Transfer Function(DBL).vi" is part of the LabVIEW PID Toolkit. You need to install that module to make QNET VIs work.
Mitch
Message 5 of 16
(4,414 Views)
hi , i also hv to control dc motor movement using labview 2009,being a new learner, help me how to build program
Message 6 of 16
(4,156 Views)
Hi Phillip,
The VIs you are missing are from the LabVIEW "PID Toolkit". In LabVIEW 2009, I believe this add-on may is called "Fuzzy Logic and PID Toolkit". Also make sure you have the "Simulation and Control Design Module" installed.
Mitch
Message 7 of 16
(4,151 Views)
What dc motor system are you using? QNET? There are many resources on how to control a dc motor in the LabVIEW Examples. Do a search through that or on ni.com and you'll find plenty of stuff.
Message 8 of 16
(4,152 Views)
hey everybody,
can anyone of u help me to get the vi in given tutorial, i make the same code as shown but its not working,
please do help
http://www.ni.com/tutorial/12944/en/
Message 9 of 16
(3,916 Views)
What dc motor system are you using? QNET DC Motor Control Trainer v1 or v2? Not all the I/Os may be easily accessed through the Express VI's when using the ELVIS II and a Quanser QNET board.
Mitch
Message 10 of 16
(3,910 Views)
