QNaN
LabVIEW experts,
I have a math question about QNAN and typecasting.  I have written code that will take a hex string and convert it to a floating point number.  For example:
hex: 0000C0C3
I swap the bytes to get it to C3C00000, integer value 3284140032, and then typcast it using 0.00 as the type.  When I come across hex strings which evaluate to negative numbers, such as 0000C0C3 and after I swap the bytes and typecast, I get -384.  Using this same procecdure in C++, I get 1.#QNAN00.  How does the LabVIEW type cast subvi actually work?
(4,443 Views)
LabVIEW typecast does already a byte swapping on the Intel CPU platforms so if you byte swap again you are back at the original byte order. On C a typecast is really just a reinterpretation and no byteswapping takes place.
Rolf Kalbermatter  My Blog
(4,438 Views)
Reading my question over again, I don't think I explained my question to well.  If I take 0000C0C3 as a string, pass it to the "Hexadecimal String to Number" subvi, I get an integer value of 49347, which I typecast to a double for a final value of 6.91499E-41.
If I swap the bytes of 0000C0C3 to C3C00000 and repeat the process, the "Hexadecimal String to Number" subvi returns an integer value of 3284140032, which I typecast to a double for a final value of -384.
The typecast subvi help file says it returns the value as *(type*)&x.  When I use this same procedure C++, it works for all positive numbers, but I get a 1.#QNAN00 error on negative numbers.  I'm just trying to understand how LabVIEW typecasts the negative numbers.
(4,428 Views)
Accepted by shivels
Hi shivels,
what happens when you typecast to a SGL (as you have a 4 byte number) in both LV and C?
Typecasting means reinterpreting a byte stream. 0xC3C00000 represents an U32 = 0d3284140032 or an I32 = -1010827263 or a SGL = -384. All use the same binary representation, just their interpretion is different...
(4,423 Views)
Gerd you saw what I had overlooked! Smiley Happy int32 cating into a double has to cause trouble. In C you can't do that as the higher 32bits are simply undefined. LabVIEW does a bit different. Seeing that the target needs a longer memory block LabVIEW appends the required 4 bytes of 0 to make it big enough to cast to a 8 byte double.
(4,420 Views)
Thanks guys thats the info I was looking for.  I kind of thought LabVIEW had to be doing something funny, but wasn't sure.  Now I'm off to try and figure out how to prevent the 1#QNAN00 in my C++ code.
Cheers,
Shivels
(4,409 Views)
