Putty error
Hello, i'm download the putty file from here :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kG6CSAU&l=en-US
And when i test it, it return to me a error message when i want to use an ssh :
Pseudo-terminal will not be allocated because stdin is not a terminal.
I'm working on labview 2013.
Wilfried
(2,977 Views)
Wilfried
You should be able to use PuTTY by itself without integration into LabVIEW.
Does it work as intended under that condition?
(2,930 Views)
If i use putty without LABVIEW, there correctly function. But with putty.vi it is not function. I don't know how to change the stdin method.
Wilfried
(2,895 Views)
