06-13-2014
03:13 AM
- last edited on
02-26-2026
03:41 PM
by
Content Cleaner
Hello, i'm download the putty file from here :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kG6CSAU&l=en-US
And when i test it, it return to me a error message when i want to use an ssh :
Pseudo-terminal will not be allocated because stdin is not a terminal.
I'm working on labview 2013.
Wilfried
06-13-2014
01:59 PM
- last edited on
02-26-2026
03:42 PM
by
Content Cleaner
Wilfried
You should be able to use PuTTY by itself without integration into LabVIEW.
Does it work as intended under that condition?
06-16-2014 12:41 AM
If i use putty without LABVIEW, there correctly function. But with putty.vi it is not function. I don't know how to change the stdin method.
Wilfried
