Putting frontpanels of sub-Vi's togeter on one Vi front panel
Hi guys,
How to put the frontpanels of my sub-Vi's to one Vi frontpanel? So they are collected at one panel.
Message 1 of 10
(4,798 Views)
It called a Sub Panel
Omar
Message 2 of 10
(4,791 Views)
Tnx Omar, And how to use this sub panel?. How I get in a frontpanel from a sub Vi?
Message 3 of 10
(4,763 Views)
In LabVIEW, go to Help >> Find Example... and search for subpanel.
Examples are otfen a good source.
Epictetus
Antoine Chalons
Message 4 of 10
(4,755 Views)
I don't know how comes the first line was duplicated a few times... not intentional.
Epictetus
Antoine Chalons
Message 5 of 10
(4,751 Views)
Epictetus
Antoine Chalons
Message 6 of 10
(4,751 Views)
@TiTou : I wish my kudos get duplicated like your posts.. LOL..Smiley Very Happy
Message 7 of 10
(4,728 Views)
See an example; I use the 'load and run.vi', I think you have it or it is available somewhere.
If the subvi is in the same dir as the calling VI, you can use this code.
The position property node is for changing the positition in the subpanel.
The code is a bit sloppy but I hope you get the point
Message 8 of 10
(4,716 Views)
Awhile back, I wrote a short tutorial, with example code, on how to use subpanels.  You can get it here.
Message 9 of 10
(4,698 Views)
Tnx, good advice here, I will look into it....
Message 10 of 10
(4,679 Views)
