em 12-09-2010 03:53 PM
Hi guys,
How to put the frontpanels of my sub-Vi's to one Vi frontpanel? So they are collected at one panel.
em 12-09-2010 04:44 PM
It called a Sub Panel
em 12-10-2010 03:23 AM
Tnx Omar, And how to use this sub panel?. How I get in a frontpanel from a sub Vi?
12-10-2010 03:35 AM - editado 12-10-2010 03:35 AM
In LabVIEW, go to Help >> Find Example... and search for subpanel.
Examples are otfen a good source.
Epictetus
em 12-10-2010 03:38 AM
I don't know how comes the first line was duplicated a few times... not intentional.
Epictetus
Epictetus
12-10-2010 05:36 AM - editado 12-10-2010 05:37 AM
@TiTou : I wish my kudos get duplicated like your posts.. LOL..![]()
em 12-10-2010 06:19 AM
See an example; I use the 'load and run.vi', I think you have it or it is available somewhere.
If the subvi is in the same dir as the calling VI, you can use this code.
The position property node is for changing the positition in the subpanel.
The code is a bit sloppy but I hope you get the point
em 12-10-2010 08:43 AM
Awhile back, I wrote a short tutorial, with example code, on how to use subpanels. You can get it here.
em 12-10-2010 01:55 PM
Tnx, good advice here, I will look into it....
