Put the data from array into listbox
Hello everyone.
I have more than one file but the listbox shows only first file (index 0 of the array). I would like to know how to bring all the values displayed in the listbox.
Thank you in advance.
(2,987 Views)
Accepted by therinoy
therinoy,
I did a small experiment with LabVIEW NXG 3.1.1 and did not see the problem:Screen Shot 2019-05-26 at 7.43.46 PM.pngScreen Shot 2019-05-26 at 7.43.46 PM.png
If you probe the array coming out of the For Loop you have, do you see your 4 elements? Is there any error thrown in the Property Node's error terminal? How about if you drop a new Listbox control to the front panel, create the reference and wire to the property node (to discard the Listbox was configured in a strange way)?
If it's still a problem, can you try LabVIEW 3.1.1 (available to download from the NI Package Manager) and see if the error still occurs?
All the best,
(2,939 Views)
It's work, Thank you so much.
(2,897 Views)
