Pulse duration in labview FPGA
Dear
can one help to built a lv FPGA to measure the pulse duration
my first start lv  VI is shown below for Spartan 3E kit the but its fail to work
is thei rany modify make it work??
for the case structure in false case the old value is moved instead of tick counter
best regards
hi ?Q>
Message 1 of 12
(6,107 Views)
Hey mangood,
Do you just want to count the number of ticks that a Digital line remains high and then output the result?
Ryan
Ryan P.
CLA
Message 2 of 12
(6,047 Views)
@Ryan-P wrote:
Hey mangood,
Ryan
 i want number of ticks that a Digital line remains high and  number of ticks that a Digital line remains low
and can work for long time for more than 1 hour
hi ?Q>
Message 3 of 12
(6,041 Views)
Get rid of the boolean shift register and the timer function inside the loop.  Just have two shift registers one for the high count, one for the low count.  If the Digital Input is True, then increment the High shift register.  If it is False, increment the Low shift register.
Message 4 of 12
(6,028 Views)
Like RavensFan mentioned, the simplest way is to use a pair of shift registers and record two of the following three: cycles high, cycles low, or total cycles. Increment the value that is currently active based on the I/O value.
What is the expected pulse/cycle rate of the signal? You mentioned reading for over an hour, do you need to have exact values for verifcatoin, a rolling average of pulse counts, a median value, etc. All of these can change how you store and process the results.
Message 5 of 12
(6,022 Views)
Accepted by mangood
There is also an Example in the NI Example finder on exactly how to do thisSmiley Happy
You can search for Pulse Measurement to find it, or use the snippet below:
Cheers!
TJ G
Message 6 of 12
(5,999 Views)
dear
thank you all for the replay
i will use the  NI Example for test
i think the iniail problem of such VI is the  timer wraps to zero.  If this timer will work under 40MHZ source clock
how long is the timer will be work without  wraping??
back again after test
best regards
hi ?Q>
Message 7 of 12
(5,972 Views)
40MHz inverted is 0.000000025  This is how many seconds a single tick takes.  If your tick counter is a U32 (the largest it goes to without extra work) you have 2^32 values which is 4294967296.  Multiply these two numbers and you get 107.3741824.  This means after 107 seconds your U32 counter will roll over.  For this to work long term you will need some way of keeping track of the amount of time passed.  I've seen some example 64 bit counters here, or here.
Message 8 of 12
(5,951 Views)
Using a U64 will work just fine for you.  It won't roll over for about 14,600 years give or take a couple decades.  I'm using a 64-bit value in my FPGA application.  I don't think I need to worry about it rolling over.Smiley Wink
Message 9 of 12
(5,941 Views)
Message 10 of 12
(5,937 Views)
