PtbyPt editing with global variable?
I tried what you suggested but the counter increments way too fast...I'm obviously missing something! I've attach the Vi if you can take a look. Stress state.
Message 11 of 17
(904 Views)
Hi Gary,
which one of your several counters doesn't work correctly?
Are you sure you need to use ExpressVIs to index an element from an array?
Are you sure you have to create multple data copies from the same waveform/data?
Do you really need all those local variables?
Are you sure it's a good idea to delete the label of a control? Did you ever wrote programs in a text-based language and had variables named ""?
Message 12 of 17
(892 Views)
I edited the pt2pt and got the functionality I was looking for. Thank you guys for the insight and solutions!
Message 13 of 17
(881 Views)
what can I do to avoid the use of so many local variables?
Message 14 of 17
(868 Views)
You DID save it as something else, didn't you?  Else, you have just made your VI incompatible with everyone else's LabVIEW installations.
[edit] This was about the worst "solution" you could have chosen.
Bill
CLD
(Mid-Level minion.)
Message 15 of 17
(864 Views)
I didn't edit the VI itself. I just copyed the code and implemented it into mine. I changed the greater than and less than zero functions to target my offset.
"Standing on the shoulders of giants"
Message 16 of 17
(858 Views)
Whew - then it's not nearly so bad.  😉
Still, I think you could definitely benefit from following some of the tutorials on this site.  It really was much simpler than modifying the code to suit your needs.
Bill
CLD
(Mid-Level minion.)
Message 17 of 17
(848 Views)
