Pseudo empty 2-d array - NPSV error 42
I am posting this more as a warning than a question.
My application has a Network Published Shared Variable that uses a cluster containing a 2-D array of Doubles.
I have found that if I write a 3x0 Array to this shared variable, it can't be read (Error 42).
If I write a 0x3, 0x0 array to it, it can be read.
How do I get a 0x3 or 3x0 array? I hear you ask
Terrific question, I will let you know when I figure that out!.
It is theoreticaly impossible but structuraly supported.
It happens in an unitiialised Class Control via typedef..
Tim L.
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
(2,758 Views)
Hi Tim,
no it's not impossible to get 3×0 and 0×3 arrays: use an autoindexing loop to produce an array containing 3 rows from empty 1D arrays (aka "no column data")…
(2,756 Views)
Figured that there would be several ways to do it, I was thinking re-dimension array. as another possible candidate.
The Problem is that I don't use any of those structures!  It is a typedef that is initialised with an empty array constant.
That said, I would not expect the NPSV to Crash because of it, especially the difference between 3x0 vs 0x3
(2,727 Views)
