Showing results forĀ
Search instead forĀ
Did you mean:Ā
Proportional Temperature Controller
I am currently doing some LabVIEW programing for a project, and I am
interested in creating a VI that will control the temperature in a
solution (using an offboard device).
It is important that this VI would regulate the temperature
proportionately, that is, that the amount of energy expended by the
device is a funtion of the ratio of the current temperature to the
desired temperature.
A professor noted that he has seen VIs that control temperature by
using a sensor that measures if the difference between the current
temp and desired temp is positive or negative. The VI then sends a
signal to a temperature controlling device that then responds with a
fixed amount of heat or cooling. This method is highly inaccurate and
tends to re
sult in overkill, one way or the other.
If anyone has some insights or examples of some proportional
temperature controlling VIs, I would truly like to see them and hear
from you.
Any help will be much appreciated.
Thanks!
- Mike
(3,483 Views)
Mike,
Without getting into too much control theory, the professor is right. You will see a lot of overshoot and oscillation with a proportional controller. To avoid this problem, you would need either a very slow heater or a PID controller (although you might be able to get by with a PI controller).
So I guess the question is if you can use a PID controller.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,483 Views)
Hallo, Mike7,
Du (kleinm) meintest am 29.05.02:
> am interested in creating a VI that will control the temperature in
> a solution (using an offboard device).
> proportionately,
What about a kind of
if abs(dt) > maxdt then let P = pmax * sign(dt)
else
if abs(dt) < mindt then donothing
else let P = factor * dt
May be that you have to implement some time loops too.
Greetings!
Helmut
Please excuse my gerlish!
(3,483 Views)
Mike,
I would suggest looking into the PID Toolset.
I would also suggest searching the following results:
Keyword Search: temperature control .
Randy Hoskin
Applications Engineer
Message Edited by Molly K on 02-18-2005 11:30 PM
(3,484 Views)
hey hows your project so far?
i am doing the same thing as you are and i really have no idea on how to start it.
if you can help me on some basic things, i would be very gratefull šŸ™‚
thnx
kleinm@bethelks.edu (Mike7) wrote in message news:<4b5c650a.0205291147.405bc418@posting.google.com>...
> using
> tends to result in overkill, one way or the other.
> from you.
> Thanks!
> - Mike
(3,483 Views)
