Property node for gauge's digital display
I found the example in this forum of using Property Node to modify the BG color of a tank's digital display.
Unfortunately, the menu of available properties is different for Gauges.
I can change the label text color and housing color, but have not been able to modify the digital display color.
(3,520 Views)
Pop-up in the digital display itself and choose create reference.
That will let you get at the properties of the digital display.
Ben
(3,516 Views)
Thank you.
That worked.
I create a reference by right-clicking the digital display.  Place that on the block diagram, insert a property node.  Tie them together and Voila!
The options I need to access are now available.
(3,501 Views)
