Property: Response to value outside of limits
Dear Community,
please have a look at the attached code. Why is it, that when I change the array inputs count and then type a value to Numeric, this value does not coerce to the nearest value as I would expect it to. Rather it does so when typing the value again.
Thanks in advance for your responses.
(2,532 Views)
Accepted by topic author labviewette
labviewette wrote: Why is it, that when I change the array inputs count and then type a value to Numeric, this value does not coerce to the nearest value as I would expect it to.
The coercion is only used when a user enters a value.  No checks are done on values that are programmatically written to the control.
GCentral
(2,513 Views)
