Involuntary movement of controls and indicators on the screen
Good Morning,
I have generated a certain VI, with controls and indicators, I have seen that by changing the screen size (maximize and modify the size of the screen) in execution makes the controls and indicators move freely on the screen.
Can this be solved in some way?
Thanks in advance.
A greeting.
(2,116 Views)
Accepted by topic author Gabrielo
Probably this:
Go to the VI properties (e.g. right-click on the VI-icon->VI properties).
Then select "Window size" and remove the setting "Scale all objects on front panel as the window resizes".
EDIT: And also remove the "maintain proportions of window for different monitor resolutions" selection.
Regards, Jens
Kudos are welcome...
(2,092 Views)
