Property Names for Waveform Chart
I want to programatically select between the two types of x axis on my waveform chart.
1) Absolute time---> Custom Time Format-->AM/PM and HH:MM:SS
2) SI Notation with 3 Digits (Digits of Precision) and Hide Trailing Zeros selected.
Does anyone know the property names for these attributes of the waveform chart? I tried looking into the list that come up when you make a property node for waveform chart. But I could not find it. I think I am certainly missing it.
BTW, I have 2 waveforms in the same waveform chart.
(3,441 Views)
Accepted by Neuropotential
What you want is XScale.DisplayFormat.Format, XScale.DisplayFormat.Precision, and Xscale.FormatString. To see the correct format strings, you can right click, select Xscale>Formatting and in the property window, select Advanced Editing Mode.
(3,433 Views)
I found the following codes for the format as follows:
%<%I:%M:%S %p>T  ---- For absolute time
%#.3p   ---- For  relative times....
I think the above format as string will be inputted to XScale.FormatString. I might not require Precision since, its already coded inside the format string.
Can you let me know what do I require for Xscale.format (integer required)?
(3,422 Views)
Turn on context help and hover over that property node.  It will tell you what each integer actually means for that property node.
(3,419 Views)
Thanks its working for me now.
(3,402 Views)
