Prompt User to Choose From Drop down Menu
Hi guys,
I am currently using the Prompt User for Input. However, I would like to link the prompt user to a drop down menu so that the user can select from a list of specific inputs. How can I do that ?
Please refer to attached photo.
Merci.
Message 1 of 9
(9,205 Views)
Hi prof,
create your own "user prompt" VI! Then you can use any control you like...
Message 2 of 9
(9,194 Views)
Think this is what you are checking for
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2BiCAI&l=en-US
uday
Message 3 of 9
(9,190 Views)
Hi Udka,
I tried that but it doesn't appear as a dialog as what Prompt User for Input does.
I tried using checkbox from Prompt User for Input.
How should I wire the selected checkbox value to my array when I have more than 3 possible checkboxes ? Please see attached photo.
Message 4 of 9
(9,166 Views)
Hi pokerprof,
-Do you mean to say that, three boolean values to case structure??
-If yes, Then you can try building an array with those three boolean values and then use Boolean Array to Number and connect this number to Case selector.
-If not, Can you please elaborate on your problem, i didn't understand clearly.
uday
Message 5 of 9
(9,156 Views)
Yes, I do mean that.
This is how I did it. Please see attached photo.
However, I would still love to have a dropdown menu instead of a checkbox in the Prompt User for Info.
Message 6 of 9
(9,153 Views)
Hi poker,
-when i said, building array and boolean array to num, i meant like in the below image (It lloks simpler)
-I think that option may not be available in that Prompt User for info.
-If you still want that feature, Then try implementing the same using the solution procived in this https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2BiCAI&l=en-US
-In the above link, Go to Implementing Custom Dialog Box >> implementation for Location selection is given as dropdown box.
-try the same and it can work for you.
uday
Message 7 of 9
(9,147 Views)
@pokerprof wrote:
Hi guys,
Merci.
You can try using the "System Ring" in the System menu. See the attached image. this creates a menu where the output is a numeric depending on which selection the user makes. This can then lead to a case structure or used to select an index from a string array to convert to strings. the "system enum" might work as well, I'm actually still experimenting with these as well.
I hope this helps you.
Message 8 of 9
(8,686 Views)
For creating user menus, you need to set the VI properties <ctl> i
You can set the window appearance to dialog. In customize, you can have the window open when called and closed when completed. Property nodes can be used to set the ring options.
Message 9 of 9
(7,481 Views)
