Prolem with While Loop
@altenbach wrote:
I don't make mistakes (famous last words 😄 ) , but sometimes I don't provide a turnkey commercial grade solution to a simple "while loop" (sic) problem, which I solved. It is up to the user to sand the edges and polish things up as needed. I intentionally did not even attach a VI.
Messing with the chart history seems like pure Rube Goldberg compared to just change the Y scaling. 😄
It would be easier to plot both C and f then simply swap out the plot visible properties and autoscale the chart vertical axis.  At the very least the scale min and max values should scale with the display unit K, C or f
"Should be" isn't "Is" -Jay
Message 11 of 15
(1,702 Views)
Accepted by WasiqSaleem1122
Here's how I would code a chart that handles multiple units.
Message 12 of 15
(1,691 Views)
As I said, here's how I would handle the Y scaling. No math needed! (I also never ever use units!)
Of course the Y axis should not be set to auto-scale as in the original code, especially if we are constantly hammering it with min and max properties. Sisyphean!
Message 13 of 15
(1,644 Views)
I use units when it seems appropriate.  Not only does it require no math, it doesn't even need multipliers and offsets.
Message 14 of 15
(1,620 Views)
Oh gee, I've been reading the title incorrectly this whole time.  I thought it was "Problem with While Loop"; but it's really "Prolem with While Loop".
Might need to see a genetic engineer about that.
Message 15 of 15
(1,618 Views)
