Projekt-Explorer Pseudo intelligence
I use the following environment.
Versioning with GIT.
The projekt is open in a “virtual drive”.
"M:\Main_Application\Framework.lvproj"
The advantage of this method is that I can handle different versions of the project, reuse it in other projects and
also I have of each PC the same link role.
Each vi is called from M.\
I also uses a lot of packed libs
LabVIEW search path standard + M:\
Compiling organization procedure: MGI Solution Explorer
My problem:
Sometimes LabVIEW load files from the real disk path
C:\GIT\Actor_Framework\Framework
This cause conflicts. Sometimes I also get linking conflicts in the “Packed Libs”. Those conflicts cannot be eliminate.
I try to delete the cache of complied objects without any solution.
I don’t know when an why LabVIEW change any paths and linking role, how I can fix it manually.
How can I deactivate this pseudo intelligence.
The project file XML contains just relative paths.
best regard,
Bodo
(1,452 Views)
Hi Bodo,
you should write your questions in English in this worldwide forum. For German discussions I can recommend the German www.labviewforum.de
@bodo_online wrote:
How can I ensure that LabVIEW does not try to load VIs from sources that I have not specified?
How can I manually correct the paths for Packed Libs.
Do you use a "virtual drive" or a "network drive"? Why don't you use the "real" path C:\…?
Packed libraries contain compiled code, I guess you cannot change the compiled code after compilation…
(1,436 Views)
see update above
(1,412 Views)
