Project file location
Greetings All,
I was given a large LabVIEW project to modify. 🙂 When opening the *.lvproj file, project manager cannot find 3 VIs.
I found the 3 files here:
..\NI Report Customized\NIReport.llb\Standard Report\NI_Standard Report_Customized.lvclass
The project tries to load from here:
..\NI Report Customized\printing\ReportDocExtensions.llb\Standard Report
Locating the correct files and saving the project doesn't change the behavior. The next time I load the project it asks for the location of the 3 files all over again. 😞
Any clues as to what I'm not doing correctly?
Running LabVIEW 2018 Ver. 18.0.1f4 (32-bit) on Win10 64-bit laptop.
Thankyousomuch!
Message 1 of 8
(3,391 Views)
More information...
This appears to be just the tip of the iceberg. When mass compiling the project folder, I get nearly 500 PAGES of errors.
My colleage gets just over 2 pages performing a mass compile on the same folder! He's running LV 2018 f2 and I'm running V18.0.1f4.  Maybe this will make more sense on Monday...
Message 2 of 8
(3,352 Views)
@jmsands wrote:
Greetings All,
Did you save any of the changed VI's so that they'll be able to find those files at the new locations?
Message 3 of 8
(3,333 Views)
@RavensFan wrote:
@jmsands wrote:
Greetings All,
The File > Save All (Ctrl-Shift-S) can help with this. Maybe try doing that if you haven't?
GCentralI'm attending the GLA Summit!
Message 4 of 8
(3,328 Views)
I'm uninstalling/reinstalling LabVIEW and components to see if that fixes the huge number of mass compile errors.
Thanks for your response.
Message 5 of 8
(3,273 Views)
Accepted by topic author jmsands
The project folder was corrupt. After getting a fresh copy and starting over, the number of mass compile errors was only a few dozen that I was able to easily repair.Sorry for not trying that right away.
Joe
Message 6 of 8
(3,229 Views)
Yes, I did this. It ended up being a corrupt project folder.
Message 7 of 8
(3,222 Views)
Yes, I tried this. It ended up being a corrupt project folder.
Message 8 of 8
(3,221 Views)
