Programmatically trigger cursor release?
I am using the Actor Framework to develop a large application in LabVIEW. I have cursors on a graph that trigger data to be populated into actors using an event structure and a cursor release event. The data is also populated (initialized) when the program starts.
I currently accomplish this initialization using a structure below, and a value change event on the 'Init' Boolean:
also described here:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-First-Run-event-on-event-structure/idc-p/1044975#M...
The problem with using the "init" Boolean is that I duplicate the same code within two events: "init":Value Change and "graph":Cursor Release events (the two event do the exact same thing).  Does anyone know a slick way combine these the Init event with the cursor release event so that the cursor release event fires on startup? This way I would not have to duplicate my code in two places...
I have searched and didn't find exactly what I needed, Sorry if this has been covered somewhere in the forum.
(4,539 Views)
Accepted by topic author mkabatek
Where will your common code run? In the Event Structure? Could you just register for both events:
Or register the event separately to send it to the nested actor:
(4,520 Views)
Hi Todd,
The code will run in the event structure. Thank you very much!! I didn't realize you could register multiple events to call the same code!
(4,508 Views)
There are a few other things to learn about events here:
http://wirebird.co/LabVIEW-Events-Tips-Tricks-Sundry
(4,499 Views)
