Programmatically setting paper size during print
Does anyone know of a way to programmatically set the paper size for printing (11x17) a VI front panel so that the user doesn't have to select it?  If this could be accomplished just by changing the VI properties, that would be fine as well.  It seems that LabVIEW defaults to the paper size settings of the printer itself and I would rather not change the defaults of the printer if not necessary.
I can't seem to find a way to do this with the Easy Print VI.
(3,208 Views)
U can set set the paper size for word and excel using this.
Message Edited by Baji on 04-07-2009 10:33 AM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,183 Views)
