Error 56 occurred at TCP Read in MB Ethernet Receive.vi
     I communicate the Unitronics PLC vision 230 through Ethernet modbus , I was read and write the PLC registers and coils earlier but currently I face the problem as an Error 56 occurred at TCP Read in MB Ethernet Receive.vi I turn off the windows firewall setting also disable the antivirus. I Check the tcp IP communication between two PC using Active and Passive TCP/IP communication vi it work properly , I also check the MB Ethernet Example master. VI on one computer and MB Ethernet Example salve. vi on other computer but this not work and also try on same computer of these two VI but communicate this two vi. Please help its urgent.
(3,541 Views)
The error number 56 is the timeout error from TCP IP read function. This is because there is no data available in the TCP IP read buffer. So I think that there is no connection problem. So please check the data flow via TCP IP communication.
MRK (CLAD)
(3,413 Views)
