Programmatically resize array element
Hi, I need to resize programmatically the element of a Matrix. The External frame of the matrix control should hold the same size, but the internal element should chang their size programmatically.
I did not find any property/method to do this. Expect using Xcontrol I guess.
Any idea?
Thank you.
(4,934 Views)
Accepted by logatto
From your image you inserted, i take it that your 'matrix' is a 2D array LED display.
In order to resize these elements while maintaining the "original size of the matrix", you have to implement two steps:
1. Resize of the LEDs:
  • Get ArrayElement reference
  • Cast the reference to Boolean
  • Set the width and height for the Boolean to the new value
Please note that now the size of ALL LEDs change. This is because all elements of an array share the same properties (including size) with the exception of the "Value" property!
Also, the Array shell resizes as it still displays the same amount of LEDs (columns, rows)
2. Calculate the new number of columns/rows to keep the Array shell at about the same size
  • Calculate the multiplier for the resize in each direction (making LED smaller to half size has the multiplier of 2 for number of rows/columns each)
  • Multiply the number of rows/columns by that multiplier (rounding???)
  • Set the dimension size property for the array shell to the new values
Please note that this will "resize the array to about the same size it previously had". Resizes due to rounding issues very likely (there are no 0.5 LEDs available!)
Norbert
Norbert
Expert: Geometry
(4,919 Views)
Thank You.
I did not find the reference for the element. It is the very first of the list Smiley Frustrated
(4,911 Views)
Hi logatto,
the element reference is a property of the array…
(4,902 Views)
