Programmatically loading values of all front panel controls
Here is a simple OpenG example that loads and saves all controls on your front panel to an INI file the file: %temp%\OpenG Config.ini
Just follow the instructions on the front panel.
Message 11 of 31
(1,658 Views)
I don't know how to add path for openG or MGI. I want the user choose where to save the file or load the file from ..
I tried using your code , but still doesn't work on mine...
Message 12 of 31
(1,635 Views)
Message 13 of 31
(1,630 Views)
It still wont work with my code 😞
I think the problem is when I try to save a pattern lets say 6,8,9,10.. so 4 elements .. if my array is currently lets say 8 element they try to load only 4 it freezes? or I might be wrong..ughhhhh
Message 14 of 31
(1,599 Views)
Even when I keep the array size the same..it loads NOTHING
Message 15 of 31
(1,595 Views)
Attach your vi, otherwise we cannot help.
Message 16 of 31
(1,586 Views)
This is my vi..I put it back the way it was after trying different things
Message 17 of 31
(1,571 Views)
Sorry, but I just cannot debug this VI. You overuse property and invoke nodes, and just violating data flow.
I really recommend to put aside this project for a while, and you should really learn how to program a proper State Machine!
Message 18 of 31
(1,562 Views)
Good idea actually.. I'm currently stuck in an infinite loop! Maybe this will get me out of misery..
Message 19 of 31
(1,559 Views)
You will see that some time investment now to practice and learn LabVIEW will actually save much more time for you later. I strongly recommend the Core 1-2 online training, very useful (you get access to these if you have a valid licence)!
Message 20 of 31
(1,556 Views)
