Programmatically deleting a splitter crashes LabVIEW
GitHub - HopeHarrison/PaneRelief does advanced splitters stuff, not supported by scripting. I think it's origins are the frustration that you can't change splitter style, so it might not actually delete a splitter (only change a byte\flag in the VI data). If there is a way to get this done, that might be a good place to start looking.
It does some pretty nasty things to achieve this.
Bob's suggestion (to use a SubPanel that loads a (reentrant) VI with a splitter and 2 SubPanels) does work, but it's a means to a shared end (dynamic splitters), not a 1-1 replacement for the scripting, that has a very specific use case.
Message 11 of 13
(444 Views)
Thanks, I've looked into the code. The low-level VI manipulations are quite insane indeed! While I see how this could be used to change a flag, removing a splitter would require changing the entire FP structure, which is yet another level of hacking into the internal structure...
Message 12 of 13
(396 Views)
Yes, I hope I didn't get your hopes up.
Modifying the FP heap (this rigorously) is probably not enough either. There are probably other structures (LVDS?) that also need adjustment...
Message 13 of 13
(380 Views)
