Programmatically autosize a string indicator
Here is a real challenge I would say: Programmatically size a string indicator and/or the window size, such that it mimics the behaviour of the 'message' indicator of the One Button Dialog box.
(3,353 Views)
This isn't difficult. You just have to find the right VIs to do it Smiley Wink
Use the "Get Text Rect.vi" in picture.llb (in LV7.1). Depending on the font and other parameters it'll return the size of the text in pixels. Use this output to set the string indicator size (maybe adding a constant) and the windows size (adding a constant).
(3,351 Views)
Can't edit my thread Smiley Surprised
It seems adding 20 to horizontal and 12 to vertical size leads to good results when using a standard string control/indicator.
Just set the size property of the string control/indicator.
(3,346 Views)
Thanks a lot Dan, I tried the Bounds property instead of the Size property. Bounds is read-only, Size can be set during run-time. The Get Text Rect.vi and related are very useful indeed.
(3,336 Views)
Glad I could help. Yes there are indeed some very useful functions hidden in the depth of the included libraries but not accessible directly from the functions palette.
(3,332 Views)
