Programmatically Write Values to a Multicolumn Listbox
Hi guys, I will be referring to the following example:
https://forums.ni.com/t5/Example-Code/Programmatically-Write-Values-to-a-Multicolumn-Listbox/ta-p/34...
The example works fine, I have no issues with it.
I'm trying to edit the example, so I don't need to physically press the button, instead, have it done programmatically.
To test it, I just created an additional While Loop, inside it, a Flat Sequence, and every 3 seconds I'm setting the Update button to true, then again to false (I had to change the mechanical action from latch to switch though).
When I press the button, the value is inserted, but every time the value of the button is changed programmatically, nothing happens...
Could someone explain why this isn't working?
I'm attaching the edited example.
Cheers,
Johnny
(3,200 Views)
Accepted by JohnatanBravo
Hi Johnny,
Changing the value of a control by user actions generates a ValueChange event, but setting the values programmatically (using local variables or "value" properties) does NOT generate a ValueChange event… (Basic knowledge about event structures!)
The quick&dirty solution is to use a "value (signalling)" property as that one will also generate the desired ValueChange event… (Beware of side effects!)
(3,170 Views)
Thank you, it's working now.
I'm only going through Core 1 at the moment, and wasn't aware of that.
Could you elaborate on the side effects? What are the possible side effects of doing this?
I'm only updating some test info using this, I don't see any possible bugs...
Working example attached.
Cheers,
Johnny
(3,146 Views)
Hi Johnny,
Each time you write to a "value (signalling)" property node an event is triggered - regardless if the value has changed or not…
(3,133 Views)
That's good to know, thanks again.
Cheers,
Johnny
(3,115 Views)
@GerdW wrote:
Hi Johnny,
As a side note, inside an XControl, a "Data Change" event will be triggered only if the value is different.
(3,083 Views)
