Programmatically Place Instance of Unsaved TypeDef
I can do this manually:
  1. Create a new typedef (a cluster), but don't save it yet.
  2. Place an instance of the unsaved typedef on a block diagram.
How do I script that?
If it's saved, I can place an instance of a typedef on a BD with this:tdc.png
But before it's saved, the path doesn't exist.  How can I place an instance of an unsaved typedef.
(So why do I want to do something so odd?  This is part of a utility that (among other things) converts some VIs from an old system to a new system.  The new system requires a typedef'd cluster constant (which is created by the converter).  I want the user to be able to examine the newly created open items, then decide whether or not to save them.)
(2,583 Views)
Wouldn't it be just as easy to save them, place them, and then remove/delete if the user didn't accept them?
(2,524 Views)
Of course that's a solution, but I was hoping for something a little cleaner.
(2,517 Views)
