Programmatically Extend a Waveform Chart
Could anyone kindly tell me what property node I can use to programmatically extend a Waveform Chart on my Front Panel.
For instance, if a Boolen button is in the True Case, the Waveform will be short, but when in the False Case, the Waveform will be automatically elongated/extended beyond the initial length.
Attached is the screenshot of what are trying to describe.
Thanks in advance.
(3,566 Views)
Accepted by Igho
Plot Area:Width
(3,553 Views)
RavensFan, thanks for your response.  It actually worked for me.    Although, you answered my question already, but just allow me to ask one more thing under this thread.  If I want a flat line known as a "baseline" a numerically controlled/adjusted value to appear on the same Waveform Chart that my incoming signal(s) is/are plotting, how do I imposed or put that "baseline" on the same waveform chart?  The "baseline" is only acting the purpose for comparison or threshold?
I would appreciate if you could just help with suggestion.
(3,523 Views)
Add a 2nd plot to your chart to display a baseline…
(3,505 Views)
