Programmatically Changing Build Specifications from command line
I use a batch file that calls a VI to build several LV projects.  I found the article http://zone.ni.com/devzone/cda/epd/p/id/5051 to get started and build projects; however, I was wondering if anyone has been able to change build specifications without opening the Application Builder dialog?  -> I would like to build an app. with a version number using the command syntax:  labview.exe <mybuild.vi> -- "project1.lvproj" "version number"
Any thoughts regarding this problem?
Adam
(4,699 Views)
I have done some research and there doesn't seem to be a way to change the version number when building a project with this method.  If I find out otherwise I will post to let you know but I don't think it is possible.  I would look for another way to accomplish what you want by incorporating the version into the file name or something like that.
Eric A.
Distributed I/O Product Support Engineer
(4,679 Views)
Any developments on this topic?  Can we change the target path of the build specification?
ALE Consultants
(4,242 Views)
Hi Terry_ALE,
Here is a forum post which has an attached example of programmatically changing the path of your application:
http://forums.ni.com/t5/LabVIEW/Build-executable-and-installer-programmatically/m-p/911384
DylanC
(4,230 Views)
