Programatically stack plots on a waveform graph
Has anyone been able to solve this mystery? Please help.
Message 1 of 8
(5,648 Views)
I guess that I am not completely sure what you are looking to do? Do you want multipule plots on a single graph or do you want stacked graphs that display data for one curve? You should be able to do either of these but it would be helpful to understand what you are looking to do.
Tim
GHSP
Message 2 of 8
(5,641 Views)
I can do multiple plots on a graph, but I want to do a stack where I can bring all the plots to the same baseline if I want to do a comparison for example. More like stacking them on top of each other where they would technically overlap on each other.
Message 3 of 8
(5,619 Views)
Have you tried to create an array with all the plots data before sending them to the graph?
Also this information might be helpful for you.
Here it is a way to handle Stack Plots or Overlay Them in a Waveform chart.
http://digital.ni.com/public.nsf/allkb/337A2E830D32A7E3862570540067AB1B
https://decibel.ni.com/content/docs/DOC-40940
http://digital.ni.com/public.nsf/allkb/349EE116C9008E39862574FE005AF617
Check out this information also:
http://forums.ni.com/t5/LabVIEW/How-to-stack-plots-using-Waveform-Graph/td-p/329917
http://forums.ni.com/t5/LabVIEW/Overlay-serial-data-over-stored-waveform-in-waveform-chart/td-p/2717...
Luis Garcia
Message 4 of 8
(5,535 Views)
Do you just want to remove different dc offsets of your channels? That's just an add/subtract once you find the offset.
Message 5 of 8
(5,518 Views)
I am able to do that.  i guess when i remove the offset i expected them to have similar baseline.
Message 6 of 8
(5,466 Views)
If you remove the dc offset, then the baseline for each should be about the same. Similar to doing an acquisition with ac coupling though not quite as precise on my experience. Show how you are calculating the offset. How much difference in the baseline are you actually seeing?
Message 7 of 8
(5,458 Views)
This is how I do my offset and stack
Message 8 of 8
(5,394 Views)
