Privileged instruction
I get Crash reporter with Exception: Privileged instruction
I know that this problem occurs when I call DLL, but this DLL is still same and yesterday its work but today not. I dont change DLL but maybe I instal and uninstal any Labview accessories like Vision Runtime, Development Modul. Is possible that I uninstal or destroy any accessories from Labview which can cause this exception? Becouse DLL is really same and all right.
Thak you for any advice,
Petr
(3,670 Views)
So you are calling some DLL here? And it SEEMED to work yesterday but is generating an exception now?
I have bad news for you here. Your Call Library Node configuration is wrong or your DLL has a bug. Unless you wrote the DLL yourself, just assume for now that you got the Call Library Node configuration wrong. Just because it didn't crash earlier doesn't mean at all that it was right.
You'll have to provide more information about the DLL involved as well as posting the VIs that access it.
Rolf Kalbermatter  My Blog
(3,653 Views)
