Programatically Change size of Labview control
Can i programatically change size of any LV control?(i.e say if i use table or listbox & if i need to change the width of table by some user specified dimension, can i do it?)
(5,447 Views)
Yes. Use property nodes (right-click on the terminal, then select "Create>Property node", as in the attached vi.
Happy New Wires !
CC
Chilly Charly    (aka CC)
(5,445 Views)
Thanks Chilly for reply.Can i do the same using ActiveX?
Cheers
murali
(5,441 Views)
There is a property node named "container bound", that allow you to change the width and height of the ActiveX control. See the attached vi
CC
(5,424 Views)
Can the same be done with a Digital control/indicator? The Bounds.Area Width property is read-only. Oh, its the TextWidth or Numeric Text.Size properties. The height is also auto-sizeable by Numeric Text.Font.Size.
(2,384 Views)
