How to combine 2 different 1D array types
I am trying to combine a 1D array of values(using a local variable) which is already in double format with a 1D array of string. How can I do this? Is there a vi or function in labview that can do this?
I hope to eventually transpose the resulting array.
Message 1 of 8
(3,317 Views)
Convert your numeric to formatted strings. (Since you cannot convert your string to numbers)
Create a 1D array of clusters, each element having a numeric and a string.
etc.
Where are the terminals?
What do you want in the end?
Message 2 of 8
(3,311 Views)
In the end, I want to transpose the 2D array( combination of the 2 arrays) and connect the output to a 'write to a spreadsheet'. I would like to open the resultant array in an excel sheet
Message 3 of 8
(3,269 Views)
It looks (to me) like you have 13 Floats and 13 Strings that "name" the Floats.  LabVIEW has something called a "Cluster" that lets you combine "related things", like the "Name of a Quantity" (a string) and the "Value of a Quantity" (a Float).
Create a Dbl, call it "Value".  Create a String, call it "Name".  Find the Cluster under "Data Containers" on the Front Panel.  Make it big enough that you can place the "Value" and the "Name" inside it.  It is now a "composite Control" or "composite Indicator".  You can find Help for the Cluster by using the LabVIEW Help, or going to Google and saying "LabVIEW Cluster" and doing some reading.  You can now make an Array of these things, and the Name will go along with the Value.
Message 4 of 8
(3,266 Views)
From the code fragment, we can tell that you are a beginner an we are here to help. As a first step, attach your vi.
Solving this problem is trivial.
Why is there so much code instead of a string array constant.
Your term "transpose" makes little sense. I assume you want two columns, right?
Message 5 of 8
(3,237 Views)
Accepted by topic author chudoe
See if this can give you some ideas
 (not attaching the VI since you seem to prefer pictures)
Message 6 of 8
(3,216 Views)
@Bob_Schor wrote:
It looks (to me) like you have 13 Floats and 13 Strings that "name" the Floats. ..
Too bad there wasn't a way of using the name of the Floats instead of creating a string with the same name. 🤔
Message 7 of 8
(3,181 Views)
Yes, this worked! I wanted to create 2 columns of data instead of 2 rows. Thank you!
I didnt add the vi because its has proprietary work data.
Message 8 of 8
(3,174 Views)
