Program to go through all text files in a folder
Hi Everyone,
                    I want to write a vi to systematically open text files in a folder, count the cumulative sum of numbers in a particular collumn, write this value to an array and then open the next text file. How can I code this in labview?
Many thanks,
Sam
Message 1 of 8
(6,354 Views)
Accepted by sw14928
Hi sw,
you should use several functions found in the file palette like ListFolder and ReadSpreadsheetFile.
You should use a FOR loop and an ArraySum function.
See how far you get…
This forum is mainly to discuss specific problems/questions regarding LabVIEW. We usually don't solve other peoples homework for free…
Message 2 of 8
(6,349 Views)
There's also a great VI called "Recursive File List.vi", so you just input the top-level folder and it will dig through the directory for you.
Message 3 of 8
(6,329 Views)
Thanks, yes I have worked through your algorythm. It currently works once only, is there something wrong with my while loop?
Message 4 of 8
(6,287 Views)
Thank you for your help
Message 5 of 8
(6,284 Views)
Hi sw,
It works as long as you run the VI. And there is nothing wrong with the while loop on its own… 😉
But the content of the while loop seems wrong to me!
What's the purpose of the shift register, when the value in the wire NEVER changes?
Why do you read the same file again and again?
What's the point in building an array from the read string?
Did you even try to debug your VI?
Message 6 of 8
(6,278 Views)
I wanted the shift register to add 1 each loop to add to the filename each time, why does it not do this? I want to build the array so that I can process the data when it is read into labview. I have tried, but my labview is not yet very good I am afraid! Thanks,
Sam
Message 7 of 8
(6,275 Views)
Hi Sam,
Because you didn't program this "+1"…
You need an additional shift register to store the array!
Well, then I suggest to take all those free learning resources offered by NI!
Message 8 of 8
(6,261 Views)
