Program Frozen
In fact, I want add a rest button for my program, however, when I add the event structure for the value change of the reset button, the program frozen. Anyone can help ?
(5,206 Views)
Never use 2 event structures in a program unless you really really know what you're doing. You should have a look at the Producer/Consumer architecture.
EDIT: have a look at this document, and this page.
Ben64
(5,194 Views)
thanks, I see.
so how to realize my "reset" function ?
(5,187 Views)
Have a look at the links (especially the second one) in the edited version of my post.
Ben64
(5,184 Views)
The reason your program freezes is that both event structures are in the same loop.
When your "Reset: Value Change" event fires the bottom event structure exits but the loop does not iterate until the top event structue also exits.
The easiest solution would be to handle both events from the same event structure.
(5,181 Views)
I put them into one event, still not working properly
(5,164 Views)
Duplicate thread.  Please keep all the discussions in a single thread.  I helps prevent fragmented discussions.
(5,155 Views)
