Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Producing a step function out of a DAQ 6009
I am trying to produce a signal from my DAQ USB-6009.
This signal will be outputed from the DAQ, to a linear actuator, to deliver a force. The linear actuator has a force sensor, to provide feedback to the DAQ.
The step function I am trying to produce is visualised in the graph below:
Y-axis (voltage in volts), X-axis (time in seconds)
+3 |                       ---------
+2 |
+1 |        -------------
  0 |  -----                          -------------------------
      0s   1s           5s       7s                         10s
Questions:
1. How would I go about producing this signal from Labview to the DAQ to the linear actuator?
2. How would I incorperate a PID controler.
3. How would I write onto the DAQ from the force sensor?
I have attached a picture of what I have accomplished so far, but I am recieving errors from the DAQ reader. I am willing to scrap this VI and start from scratch if that would make it easier.
(5,915 Views)
Hi Jake,
using Control&Simulation loops is likely overkill for this problem…
I suggest a simple FOR loop: set a voltage and wait the delay. In the next iteration do the same. Your example translates to "coordinates" (voltage/delay pairs): (0V, 1s), (1V, 4s), (3V, 2s), (0V, 3s). Put those into an array, the FOR loop will autoindex them…
Use the PID function found in recent LabVIEW versions. It comes with example VI, so study them!
Use an analog input of your USB6009 to read the force sensor signal…
LabVIEW and DAQmx come with a lot of example VIs. Study them!
(5,903 Views)
Thanks for the reply.
Could you please claify "voltage/delay pairs".
I am a novice user at LabVIEW, any step by step explaination would be helpful.
(5,898 Views)
Hi Jake,
You want to output a certain voltage for a predefined time: So you have to define a pair of values, one voltage value with one time/delay value…
See this simplified example:
check.pngYou can also use a 2D array instead of 2 1D arrays…
Btw. you know how to produce "screenshots"? 😄 (Or is your LabVIEW computer not connected to the internet?)
(5,886 Views)
I was just responding to you on my mac laptop, and it was easier for me to take a picture with my phone and send it there rather than screen shot it from the windows one, haha.
(5,872 Views)
