Processing undefined values on a Menu Ring indicator
   I am using a Menu Ring as a indicator to perform a "captain midnite decoder ring" for 1 byte hex values that come from the hardware I am working with. Since the 1 byte hex value can have 256 possibilites I do not want to have a menu ring with every possible value. Currently when a undefined value is received by the Menu Ring Indicator the Menu Ring display the value it received with open and close carrots, which is not always obvious to a "non programmer" person that a undefined value is present.
  I was thinking of putting a case structure infront of the Menu Ring indicator that would "screen" the input values to the currently defined values.
Kaspar
Kaspar
(3,305 Views)
Carets, not carrots. Let's keep Bugs Bunny out of this. Smiley Wink
You don't need to do anything all that complicated for this. You can create an "UNDEFINED" value that has a value of -1, and then just use the "Values" property to search for the input value in the list of values you have. See attached.
Message Edited by smercurio_fc on 07-09-2007 09:47 AM
(3,293 Views)
Thank you! I will try it out!Smiley Happy
Kaspar
(3,281 Views)
That's not fair!
Blue property nodes are "right out" (operating instructions for the Holy handgrenade, MP's Quest for the Holy Grail) Smiley Wink
Ben
(3,276 Views)
Hah! You know I wrote that example so fast I hadn't even noticed!
(3,266 Views)
A more "technically" correct version based on not using blue property nodes:
Message Edited by smercurio_fc on 07-09-2007 10:45 AM
(3,264 Views)
