Processing Teststand xml report with labview
I would like to build a tool (using Labview) to analyze the test protocols generated with teststand. I am interested on extracting the  name of the test step which caused an error on my sequence. Could anybody tell me how I can do this?
For example, in the test protocol shown, I would be interested on extracting that my test failed at [6]_Led_Test, and I would also like to extract that it failed at the test step Test_ButtonPressed_PASS. The problem is that I do not see how. I would be able to find looking by the tag "CriticalFailureStack" the sequence where it failed, but I do not see how I can find the test step where it failed. Has anyone a solution?
capahlmh1985_0-1678887706553.pngcapahlmh1985_1-1678887733269.pngcapahlmh1985_2-1678887772907.png
(1,468 Views)
Hi capahlmh,
Do you even log/report the steps within the sequence?
They only appear in the report when you enabled logging for all steps…
(1,463 Views)
"Do you even log/report the steps within the sequence?
They only appear in the report when you enabled logging for all steps…"
Hi, yes sure I enabled logging for the step I am looking for. It is possible to see it in the protocoll 🙂
(1,437 Views)
Hi capahlmh,
mind to attach the complete report (in a ZIP file)?
(1,432 Views)
