Process data in a circular buffer file
Hello, I've created a 5 min circular buffer, which writes to a binary file whose format is simply a 2D array of DBLs. When a fault occurs, I'd like to restructure the post-mortem data so that if the buffer has circled over, the data between the current file position marker and EOF is placed at the beginning of the file, before the data that was last written. Please see attached art piece.
I'm trying to do it without reading in the data because the files are usually large (if they were logged at 1000 Hz, the file is greater than 80MB). I was wondering if there was a way to do it by copying to another file, perhaps playing around with the EOF markers. Is there a way to "merge" two files without necessarily reading and writing?
Sima
(3,114 Views)
I can't think of any way to move data around in a file like that without explicitly rewriting it. The only thing I can think of is to write a specially formatted header to the file when a fault occurs that can tell the data reader where to start in the data. This could create the same operation without actually moving the data.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,098 Views)
What about keeping the data in memory instead? 80MB's is peanuts. You write your data to the file only once the fault has occurred. Save yourself the read time.
(3,095 Views)
